Beovision Harmony speaker cover adjustment
This post has 24 Replies | 0 Followers
pastaj
Posts 53
pastaj Posted: Sat, Jan 15 2022 3:31 PM
Hi all. Looking to poll the audience of harmony owners out there. From day one out of the box, my harmony speakers have a misalignment and I was told that this is normal but for a $20,000 TV, this seems unacceptable. Specifically, my problem is that when the tv is fully open and upright, the speaker covers flare out at the end. If you measure the distance from the speaker cover to the tv panel (in the middle of the tv) vs out at the edge of the speaker covers, it’s nearly double. This ends up giving the two speaker covers a toed in appearance and not a nice flat surface paralleling the tv panel. Can someone please shed light on this? Has anyone else noticed this? I’ve gone through all the panel adjustments as well as I believe all of the internal BO videos to adjust the speaker boxes if they are warped or curved and nothing has been able to correct this. It’s almost as if it’s intended or part of the movement bc the tv and speakers will open fully but right at the end of the mechanized movement as they are perfectly aligned, then they motor just a bit more and it kicks the ends out and then leaves a subtle “v” shape when looking at the tv from the side. I hope this makes sense and possibly Someone can confirm this is normal or not. Thanks!
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Jan 15 2022 3:40 PM
Yeah, that’s not normal.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
pastaj
Posts 53
pastaj replied on Sat, Jan 15 2022 3:49 PM
Appreciate the reply! I’ll reach out to my dealer about warranty
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Jan 15 2022 3:50 PM
Mikipidia:
Agree, not normal.
you are sure the covers are appropriate installed ?
pastaj
Posts 53
pastaj replied on Sat, Jan 15 2022 3:57 PM
Just to be 100% mikipidia, you’re saying that on your harmony, if you were to lay a level across the front of the speaker grills, from left to right, they would be perfectly flat and parallel to the tv panel? Just want to make sure I’m describing my issue correctly. Best way to describe my issue would be as if someone came up to the tv and kicked the middle of the speaker covers and now the middle of the speakers (where the white light is) is closer to the tv than the ends. If you were standing over the tv and looking down with a birds eye view, the tv panel would obviously look like a straight flat line but the speakers grills look more like a V, with the out edges (left and right) further away from the tv than the middle edges. The two surfaces would not be parallel.
pastaj
Posts 53
pastaj replied on Sat, Jan 15 2022 3:58 PM
I wish I could take a pic to show you but yes. I’ve uninstalled them multiple times and I cannot see how they would be installed incorrectly. But I’m open to any and all ideas
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Jan 15 2022 4:16 PM
I know what you’re saying, it’s not normal. I’ll post pics in a few minutes. It sounds like it’s bent if the screws/allen bolts on the back can’t pull it straight. https://m.youtube.com/watch?v=yKijOXP_CU0&list=PLRPmJ785xnMhzU7YPcFlBxzNRSY4ewyQV&index=17
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Jan 15 2022 4:21 PM
Just noticed one of mine moved the tiniest bit over time, but it’s still as good as straight. Not noticable from the frontStick out tongue
vlohjr1
Posts 553
vlohjr1 replied on Sat, Jan 15 2022 4:23 PM
pastaj:
I know exactly what you mean. I had the same experience. The initial dealer didn’t adjust the screws properly. In the end bang okufsen authorised their uk repairer and readjusted it again and it was fine.
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Jan 15 2022 4:23 PM
Went to mods i think, will try again later.
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Jan 15 2022 4:24 PM
pastaj
Posts 53
pastaj replied on Sat, Jan 15 2022 4:41 PM
ok, so you had the same issue and they were able to correct it through simple adjustments to the unit? I know there are a few allen key adjustments that i have been instructed to try but those do nothing but move the screen forward, backward, up, and down. To me, if they were to come out and simply adjust them back to straight, that should be something easy enough to tell me to do over the phone and so far my dealer hasnt' mentioned anything like this. All of the known adjustments (to me) are simple fore aft up down type adjustments. To fix this issue you have to adjust the camber of the speaker grills, but this harmony was shipped from BO to my house, no dealer in the middle, so maybe it missed an adjustment step. Thank you all for the replies, i thought i was going to be out in the weeds on this one. Glad to know its a known issue and not normal.
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Jan 15 2022 5:31 PM
Follow the link i sent you, the bottom allen keys do the wing tips
Mikipidia
Posts 2,169
Mikipidia replied on Sat, Jan 15 2022 5:33 PM
Ps the bottom ones are covered by plastic tabs. They are in the middle of the soundcenter. About 10” below the cables in the middle if the metal back.
vlohjr1
Posts 553
vlohjr1 replied on Sat, Jan 15 2022 5:47 PM
pastaj:
I wouldn’t say it’s simple adjustment
2 people came and still took a good half hour to get it Reasonably aligned. The video says you need to adjust anyway but it’s not as simple as it looks
Don’t mess around if you struggle get the dealer to do it!
pastaj
Posts 53
pastaj replied on Sun, Jan 16 2022 3:45 PM
thanks for the link. ive watched that one and those are the only adjustments i know of. ive done all of those but if you watch what is moving while you are adjusting the screw, its the tv panel that moves forward and backward, up and down, and the fore aft adjustments seem to be for the upper half of the tv and the lower half of the tv. While watching the speaker covers, these do not appear to move. In order to solve my issue it would seem that each speaker would have an adjustment to change the angle of the speakers and covers. Ideally, an adjustment that changes the toe in angle of the two speakers. For me, i would like them perfectly aligned, not toed in. So, if some other adjustment exists, it will have to be done by the dealer/repairer bc i am unaware of any other adjustments. If you take off the lower back panel, maybe there is something there bc to me it looks like there needs to be an adjustment of the upper arm that the speaker pivots on. If you push this arm outwards, toward the listener, it would then push the middle out and pull the ends of the speaker back. Think pushing your chest out while pulling your shoulders back. Im thinking this must be an adjustment issue bc it would be highly unlikely that if something was bent due to shipping, etc, that it would be perfectly bent on the left speaker and the right speaker. If anyone knows of other adjustments, please let me know. Im going to reach out to the dealer to see what they have to say. This should be covered under warranty, correct?
Mikipidia
Posts 2,169
Mikipidia replied on Sun, Jan 16 2022 5:03 PM
pastaj
Posts 53
pastaj
Posts 53
pastaj replied on Sun, Jan 16 2022 6:59 PM
Well, I have have no idea how to post a pic here but I was able to post one to the media forum. You can see it there and notice how the speakers are angled. Thanks all for the help
Mikipidia
Posts 2,169
Mikipidia replied on Sun, Jan 16 2022 10:30 PM
Mikipidia
Posts 2,169
Mikipidia replied on Sun, Jan 16 2022 10:34 PM
Those two i just circled in my last picture pull the harmony wings in or out. They have no effect on the screen distance at all. Pull the plastic cover tabs out and you need a 4cm 3mm allen key, they’re fairly deep. Clockwise they pull the ends of the wings in iirc.
If you installed it yourself i doubt that wrongful installation is covered under warranty, especially if it can be fixed by adjusting the screws. But now having seen how yours is, it seems like a simple adjustment and not like it’s bent at all. So that’s good Wink
pastaj
Posts 53
pastaj replied on Sun, Jan 16 2022 11:03 PM
Thanks! I’ll have to check again but on mine, when I remove those plastic tabs, there is a 3mm Allen bolt no more that a few mm in. Definitely not 4cm. So maybe I’m missing that one. I’ll have to crawl back there and look again. Appreciate the help!
Mikipidia
Posts 2,169
Mikipidia replied on Sun, Jan 16 2022 11:07 PM
Maybe that’s why Stick out tongue
I have allen bolts on a ratchet and they’re about 1cm long but the don’t reach mine at all, the collar touches the back plate of the tv before the allen head is even in.
pastaj
Posts 53
pastaj replied on Sun, Jan 16 2022 11:46 PM
I don’t know. Maybe ours are constructed differently. When I pop off the cap, there is an obvious Allen bolt, 3mm, right there. Hardy a few mm in. The only way to go deeper is to angle the Allen key to go around the head of said bolt but then you’re going in with a slight angle. Anyways. I’m just gonna have BO come fix it. Hard to say it’s installation error when you pull the cardboard top off and voila, it’s set up. Hopefully they won’t play that card
Page 1 of 1 (25 items) | RSS
