Has anyone got and photos and details of how to replace the cassette belts on the Beocord 5000 please
You might find something useful at:
https://beolover.blogspot.com
Thank you Eddie,unfortunately my cassette is older than they have info for
There are two different Beocord 5000 decks. The "older" deck belt replacement is here:
https://beolover.blogspot.com/2014/10/beocord-5000-47154716-replacing-belts.html
The "newer" is here:
https://beolover.blogspot.com/search?q=beocord+5000
Please correct me if I am wrong.
This really helps ,my machine is the 4922 not 4923 , I am not sure if that makes much difference.
I am making good progress. I just need a photo of where the belts actually go to
thanks again
mike
I can see that you are a Gold member - so you can find a service manual for your Beocord here on Beoword.
Everything Bang & Olufsen - BeoWorld
