Beovision 7 mk3, hdmi question
This post has 1 Reply | 0 Followers
Dinobaggio
Posts 3
Dinobaggio Posted: Sat, Jan 29 2022 3:52 PM
Hi I have a beovision 7 mk3, with 4 hdmi ports.
I have a STB in hdmi b, and set up as av source 3, vmem in connections and v mem on my beo4 remote.
I am trying to set up a second box (mag box) into C of the hdmi ports.
I am really struggling to get a picture- I’ve set up V aux on av 1, hdmi port c.
Press v aux on remote- no luck. Tried it on all av sources but can’t seem to work it.
Is what I’m trying to do possible, or am I out of luck on this?
thanks in advance
Dinobaggio
Posts 3
Sorted- many thanks.
for anyone else with the issue- it’s quite simple once worked out!
Set AV 2 to PC, ensure HDMI is enabled and correct port selected (a/b/c/d)
Add PC to Beo4 remote by pressing list and power button at same time- scroll up for “add” then scroll and select PC - press go.
Now should find that by pressing “list” on beo4 until PC is selected will bring up PC on the remote and the kodi/mag box will show through the beovision.
Page 1 of 1 (2 items) | RSS
