Beocenter 9500 CD Problem
This post has 0 Replies | 0 Followers
Dave
Kent,UK
Posts 2
Dave Posted: Sat, Feb 5 2022 9:59 PM
Hi, I have a problem with my beocenter 9500 it was working fine until the other day! I was listening to a cd for about 30mins and then it stopped and the beocenter turned off. Now every time you select CD it will do nothing for 20 seconds then turn off. if you cycle the power the cd will spin for less than a second and shut down, then if you try again it does nothing. The 33uf 16v cap on the servo board has been replaced. All its other functions work fine.
Thanks in advance
Page 1 of 1 (1 items) | RSS
