Hi
Beovision 8-26 frame has that "rubber" coating.
Is there any possibility to remove or fix scratches on that kind of surface?
Ipe
Ipe:Hi Beovision 8-26 frame has that "rubber" coating. Is there any possibility to remove or fix scratches on that kind of surface? Ipe
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
yes it's also kind of sticky. Removing would be very difficult without dismantling the frame first.
