Maybe someone can help me?! I have an existing ML system. There the BV7 is the video master and the BS9000 is the audio master. A BLC with IR is integrated. A Beosound Moment is connected to it. The speakers are connected to the BV7 (BL5, BL3). I can call up all the sources from the BLC via the Beoremonte Halo, only the volume control doesn't work. But I can control the volume via the B&o app. Is this not possible in the constellation to control the volume via the Beoremonte Halo or have I made a mistake? Thank you for your help in advance.
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass, BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence , BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white, Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
The Halo does not yet support volume control of ML products. I have the same issue with my BeoVision 10 and two BeoSystem 3 TVs. I've reported the issue to BeoCare.
