Beogram 1203 runs slow but then speeds up to correct speed
JeremyCosta1
Posts 5
JeremyCosta1 Posted: Sun, Feb 20 2022 4:35 AM
Hi All, so i have a beogram 1203 that i have been refurbishing for about a year. It runs real well now apart from one problem, It starts slow but if i leave it on for 20 minutes it eventually runs at the perfect speed and will continue to do so as long as i keep playing records. If i stop for about 30 minutes it slows down again and i then have to let it run for 20 minutes again. I have pulled it apart and re-oiled it a few times and initially that seemed to work and lasted about 6 months but now it's running slow again, i opened it up re-oiled the bearings and there doesn't seem to be a change this time. does any body have any ideas as to what it could be?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Feb 20 2022 8:01 AM
Wrong oiling method
Wrong oil
Worn bearings
Any combination of the above.
Replace the bearings.
They can be found (and read the description) here:
https://www.beoparts-shop.com/product/motor-bearings-set-for-beogram-motor-with-3mm-spindle/
Page 1 of 1 (2 items) | RSS
