Wiring arm Beocenter 2800
Freez
Posts 1
Freez Posted: Tue, Feb 22 2022 7:14 PM
Gentlemen,
As a new member i sincerely hope you can help me with this problem. Standing in a corner there was a old Beocenter 2800 once used by my father.
I wanted to do some restoration on the device, so far i have gotten everything in working order again, even the arm lift and positioning is now fully functional. (Lifting pin was completely stuck and needed quite some persuasion to get going again)
However, three of the ridiculously thin copper wires that come from the stylus through the arm are unattached, three were still attached. I have soldered them to where i would assume they should go, but i am still missing the right channel on the stereo signal.
Anyone have the method to figure out which wire goes where?  I think the wiring on a Beogram 1600 should be the same or similar. If i get a hint on how to figure out the wiring i would be happy.
Kind regards,
FreezSmile
Page 1 of 1 (1 items) | RSS
DigiCert Secured Site Seal
