Can anybody help me with locating and adjusting the Reed Switch inside my Beogram CD5500.
The CD drawer sometimes closes immediately after opening. I'd like to fix this and could use some advice.
While I'm at it. The "5" digit on the cd player is gone sometimes. I reckon this has to do with a solder joint. Any experience with this?
Nico
Not actually reed, it is open type located on left side of rails, just about in middle on front of pulley. As it is open, it cloud have dirty contacts or tired springs. Maybe you can find suitable microswitch to replace.
Bad pic, I had better in old forum, I check if it is aviable.
There, right in middle
lanka3.jpg.aspx
Thanks for the help. Great!
