Scratches to Beocenter 9500 mirrored doors and centre panel
This post has 8 Replies | 0 Followers
Ronnie
Milton Keynes, UK
Posts 110
Ronnie Posted: Mon, Mar 19 2012 9:33 AM
Hello there, i have seen one of these at a good price but was wondering if there is a way to remove scratches from the mirrored panels as they are heavily scratched. Or if i am able to buy new ones?  if so if anyone knows how much i would be grateful.
Thanks In Advance!
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Mon, Mar 19 2012 9:59 AM
Don't think it's possible to remove scratches on these type of panels.
I think I must have some in my closetSmile
Brengen & Ophalen
SamWise72
Posts 53
SamWise72 replied on Mon, Mar 19 2012 10:22 AM
Anything's worth a try with a buffing wheel, I'd guess.
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Mar 19 2012 10:37 AM
Whatever you do, they'll only get worse, and you'll end up wishing you had left the scratches alone.
I suppose parts for 9300 would be still available, but I believe they have a bit different finish.
--mika
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
ronnie1995:
Thanks In Advance!
Polishing them will only make them worse. The polished panels fitted to early 9300's are anodised aluminium and the anodising will simply be removed leaving dull aluminium, which looks horrible.
The only thing you can do is replace them with new service spares which are still available, as a set of 3 matched panels. See your local B&O dealer. They will cost you around £180.
The matt panels fitted to later 9300 are made of treated steel, are much harder wearing but have not been available for around 12 months now
Regards Graham
joeyboygolf
Posts 4,188
Leslie:
Have I not sold you some used sets Leslie?
Regards Graham
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, Mar 19 2012 12:06 PM
No, I don't think so Graham. On the other hand, I did order a set long time ago through Ebay, and maybe I bougt them from you? I was not aware that you were the owner of Beo4life. We did some exchanges though but not for panels!
Brengen & Ophalen
joeyboygolf
Posts 4,188
Leslie:
I have sold several sets of second hand panels and my wife has sold a few.
I fit a new set to every Beocenter 93/9500 I sell and sometimes the old ones are just too good to throw away!
Regards Graham
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, Mar 19 2012 10:54 PM
Then I'll keep mine as a spare Graham (sorry Ronnie). I think I bought them from you but that must be a while ago. They look brandnew...
Brengen & Ophalen
Page 1 of 1 (9 items) | RSS
