Hi everybody!
I am to get myself a Beoplay V1 TV set.
Is it possible to find a list of the operateable devices working with the V1 via PUC codes? Or are they only visible on the screen of the V1?
It would be nice to know in advance if my DVD player or Settop Box can be operated via the Beo4...
Greetings Jakob, DK
If you post the make and model of your DVD and set top box, I'm sure that somebody on BeoWorld can check for you :-)
Opman
Hi Jakob,
and welcome to Beoworld.
Keith made a list of available pucs. Have a lokk here:
http://archivedforum2.beoworld.org/wikis/puc/default.aspx
m.v.h.
Stefan
Hi Stefan
That's what i needed! Thank you
Hilsen Jakob :-)
[EDIT:]
In the Wiki mentioned above it says that the PUC Code list is made available to dealers who can then provide updates to meet their customers requirements.
Does that mean that I have to contact the dealer every time i get myself a new 3rd party device (ok, may not happen that often )? I thought I could download the PUC Code myself within the Beoplay V1
The wiki you are looking at are probably based on the older B&O TVs.
Beovision 11 and Beoplay V1 differ from these, as the installation of PUCs is done by the customer at an easily accessible on screen menu.
The only time you need to contact your dealer, is when the device you are looking isn't in the list. Then your dealer can help you add that device.
The PUC list is constantly updated, and the best way to check for compatibility is by asking someone in here is the device is present.
Beovision Eclipse gen2 (GX) w/ floorstand, Beolab 14.2, 4 speaker Shape and ATV4/Chromecast.
Beoplay A9mk4 GVA, Beosound 1 GVA, H2, H3, H8, E6, Beoplay EQ
Ah, ok, thanks again
One white Beoplay V1-40 ordered yesterday! Can't wait...
