Hi everyone,
I'm having some issue setting up the counterweight and pickup on my newly acquired Beogram 1202. I'm following the instruction manual but when I set the stylus pressure adjustment as suggested (2 ponds for the SP14 stylus), it looks as if it makes the arm to low. I'm not sure if the support leg is at the correct height but i'm not sure what the correct height for the leg should be. I'd say it sticks out a couple threads / 1mm above the arm... I've gone through the owners manual and service handbook but can't seem to get it right!
Does anyone have any tips on how to set up the counterweight and pickup correctly with the SP14 stylus?
Any help is much appreciated!
