Phones
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael Posted: Fri, Mar 29 2013 5:38 AM
Hi
Would a beocom 2 be able to be used in an existing phone setup ?
For example if you have a Panasonic phone setup in 2 rooms, could you hook a beocom 2 into a phone jack in another room and if someone called your number all phones would ring?
Or do you need to only have a B&O phone setup?
Michael
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Mar 29 2013 11:30 AM
It depends a little on what you mean! You can get a stand alone Beocom 2 (the original type) in which the base has the wireless connection in it and this connects to the phone socket and would work exactly as you desire. Later BC2s work with a Beoline wireless set up so the base is merely a charger and you need a separate device connected to a phone socket - this has the advantage that the BC2 can be situated almost anywhere - it still needs a power feed.
Peter
Page 1 of 1 (2 items) | RSS
