link set turns itself back on??
Nick
Nottingham
Posts 785
Nick Posted: Fri, Mar 29 2013 12:29 PM
Hi all,
  I have a bv7-40 as the main set & a beocenter 6-26 as the link in my bedroom. After watching the set up stairs I turned it off and watched the tv downstairs, when i nipped back upstairs the set had switched itself back on but TV, so white noise is showing??  Any ideas what maybe the cause??
Thanks Nick
Langleyav
Windsor UK
Posts 226
Langleyav replied on Fri, Mar 29 2013 1:07 PM
As the BV6 is designed as a Master as well as a slave (in a link room), make sure that the option setting is 6 when using it in a link room, and also that the timer play is switched off.
Ron
Nick
Nottingham
Posts 785
Nick replied on Fri, Mar 29 2013 7:32 PM
Hi thanks for the reply, its set as option 6?? I will check the timer play feature but it seems to do this quite a bit
Cheers Nick
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Fri, Mar 29 2013 8:38 PM
Have you got a Freeview box connected directly to the Link TV? If scart sense is activated, the TV will switch on from stand by when the Freeview box responds to a software update over air.
Opman
Nick
Nottingham
Posts 785
Nick replied on Fri, Mar 29 2013 8:42 PM
no nothing connected to the link tv only masterlink & aerial (signal from main tv)?
It only happens when if i watch tv in bed at the weekend and then turn the tv on down stairs i return upstairs to find the link tv on but on tv so showing black & grey fuzz?
Langleyav
Windsor UK
Posts 226
Langleyav replied on Sat, Mar 30 2013 12:05 PM
I would suggest that you disconnect the masterlink into the rear of the BV6 and see if that cures the problem. If it does then it sounds as though the TV downstairs is sending a command to the BV6 via the masterlink circuit.
Ron
Nick
Nottingham
Posts 785
Nick replied on Sat, Mar 30 2013 12:21 PM
Langleyav:
Ron
thats what i think is happening, does anyone know what the colour wire is that sends the command to the link set??
hfat
Vienna, Austria
Posts 663
hfat replied on Sat, Mar 30 2013 6:34 PM
Hi Nick,
have a look here: http://www.beoworld.org/beotech/wiring4.htm. It's pin1+2 white/green, green.
hfat
Nick
Nottingham
Posts 785
Nick replied on Sat, Mar 30 2013 9:48 PM
Thanks Nigel
Page 1 of 1 (9 items) | RSS
