Beovision 3 motor stand
This post has 3 Replies | 0 Followers
Ray
Bromley, Kent
Posts 13
Ray Posted: Sat, Mar 30 2013 6:52 PM
am i right in thinking that you lay the BV3 on its back to fit a motor base, or am i about to make a horrible mistake?!
Ray
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Mar 30 2013 8:21 PM
If you lay it gently for a few minutes on any side you will do no damage.  Use plenty of cushions or a duvet and all will be fine.  Lots of people will give advice about transporting CRT TVs but for a short period you need not worry.
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Mar 30 2013 9:07 PM
If laying it on one side is possible, i would prefer this. Transported mine this way in a car, for example,
Ralf
Ray
Bromley, Kent
Posts 13
Ray replied on Sat, Mar 30 2013 11:12 PM
Many thanks guys, i'll try it on its side. Its only to fit the motorised base so only five or ten minutes Smile
Ray
Page 1 of 1 (4 items) | RSS
