Beocord 3500 won't work :(
Evuul
Posts 1
Evuul Posted: Fri, May 3 2013 12:17 PM
Hello! I received a tape recently that i want to play. Problem is: It won't play..
When I put the casette in to my Beocord and push play, it clicks two times and then nothing happens.
Anyone out there who knows what the problem might be?
Cheers!
BeoHut
Posts 482
BeoHut replied on Fri, May 3 2013 12:36 PM
When was the last time when you used your Beocord?
First have a look at the belts. They probably need a replacement.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, May 3 2013 12:46 PM
Try with a different tape to see if the problem is with the Beocord or the tape.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, May 3 2013 12:48 PM
And possible a proper cleaning inside....
Some belts give the same mess as speakers with foamrot... Next stage is to remove the old grease and use new one around the capstan and other moving parts.
Page 1 of 1 (4 items) | RSS
