beocord 6500 stuck with heads in out position
Arvin
toronto, canada
Posts 3
Arvin Sad [:(] Posted: Fri, May 3 2013 5:38 PM
Hello there,
I really would like to reset the heads on the the beocord to go back in. any suggestions out there.
thanks
Arv
own a 6500 with beolab penta 2 speakers
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, May 3 2013 6:51 PM
Depending on the drive type, there are ways to get the tapeheads to disengage but
the problem is that the drivebelts are slipping. Because the moving of the tapeheads puts
the max stress on the belts, this is what usually fails first and even if you manage to
disengage the heads they will lock up again next time you press play.
Replace the belts.
Arvin
toronto, canada
Posts 3
Arvin replied on Fri, May 3 2013 7:00 PM
Thanks Martin
Are the belts difficult to replace/1 or 2 belts? (somehow I always thought it was direct drive??)
 Are they easy to get?
Dillen
Posts 13,191
Dillen replied on Sat, May 4 2013 3:18 PM
It all depends on your skills.
There are two deck types; One has one belt, the other three.
The latter is a bit tricky to work with.
I can supply belts for both types.
Page 1 of 1 (4 items) | RSS
