Any help with this? I'm purchasing either one, depending on which one is better. Please help!!! Thanks!
I take it that you are in the US as the 1602 is not so common over here! What are you planning to use it with? The RX has RCA plugs, the 1602 a DIN plug. I would be tempted to get the RX simply because it is quite a bit newer but sonically I would suspect both sound similar - and very good! Make sure they fully work!
Peter
Will I be able to connect the DIN plug to any receiver?
No, but DIN-->RCA adapters are plentiful.
Dont worry about din plugs, get a deck with a working pickup, MMC 4 or equivalent, if the deck do not come with a pickup you will have to buy one for 150-250 USD.
Very true!
