radio beocentre 2
This post has 4 Replies | 0 Followers
malcolm welborn
canary islands
Posts 188
malcolm welborn Posted: Thu, May 9 2013 6:41 PM
hi had my beovision 11 installed and dealer informs me radio can no longer be played through the beocentre 2 but will be played through the tv and if the station is not listed  I cannot programme.any other station.
I live in lanzarote and tthere is a local radio station in English playing music which is not listed in the tv only mainland spain stations or las palmas stations all these stations are playing mainly Spanish music
no problems playing cd or dvd through beocentre 2
in fairness to them they are looking into this but wondered if anyone with bv 11 have this problem to and have any answers
I cannot believe beocentre cannot be integrated
malcolm welborn.
tompa
Posts 64
tompa replied on Thu, May 9 2013 7:29 PM
Hello,
You need a network link converter to intergrate Masterlink audiomaster with new networklink Products like BV11 and V1
they should as dealer know that if you do that no problems to get radio on beocenter2 with BV11
malcolm welborn
canary islands
Posts 188
many thanks for info , will pass on to the dealer. in fairness new dealership and is checking
malcolm
Beoberg
Odense, Denmark
Posts 315
Beoberg replied on Fri, May 10 2013 10:05 AM
May I ask how your BeoCenter 2 is connected to the BeoVision 11? I have a similar set-up. It bothers me, that I have to turn on the BV 11 everytime I want to hear CD from the BC2. The only option I figured besides the insanely expensive ML/NL converter, was to connect the socket unit and the TV through SP/Diff coaxial cable. This works fine with CD but radio does not work as the socket unit only outputs radio from the analogue chanel (sadly).  I have tried to connect the BC2 to BeoLab 9's through powerlink cables and then having powerlink cables from the BeoVision 11 going to the Lab 9's aswell. This resulted in electrical noice and strange behaviour.
Kind regards,
Frederik
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
malcolm welborn
canary islands
Posts 188
hi  there
im not a tech man dealer installed, all I know is to play radio through the bc2 need the network converter 600 euros, to play cd or dvd press dvd in both cases on beo4 or touch on beo6.
I will play radio if needed through satellite tv
malcolm
Page 1 of 1 (5 items) | RSS
