BeoGram 4000 series 33/45 Speed change relay substituted
This post has 6 Replies | 2 Followers
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Hi all,
I ran out of spares of the original Siemens relays, and so had to make do with what's available on the market. Success, and no reason to go chasing down unobtanium anymore - at least for this.
The successful substitute is a Schrack RTE24024 DPDT 24VDC relay.
Obviously the pinout is completely different but this is not a problem.
This is the original pinout
Menahem Yachad
Jerusalem, Israel
Posts 1,249
And here it is installed - once the PCB is bolted down, it looks just fine.
However, if there is sufficient interest, I can make up a small adapter PCB to enable the new relay to fit right into the original holes, similar to what Brown-Dog does for IC's of differing pinouts.
Menahem
Step1
Manchester, UK
Posts 1,268
Step1 replied on Mon, May 13 2013 2:43 PM
I made a small batch of pcb's for Osram sealed relays, it makes the whole process a heck of a lot easier! I will upload the print when I get a minute of time! I use to glue the osram relay upside down and feed the wires over the top nice n neat and don't have to worry about the thing rattling round ;-)
Olly
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Hi Olly
I'd definitely like to see that PCB of yours!
Menahem
Peter
Earsdon
Posts 11,991
Peter replied on Mon, May 13 2013 4:55 PM
Very clever, the pair of you. Nice to see solutions to problems!
Peter
Menahem Yachad
Jerusalem, Israel
Posts 1,249
We try!
Idea
Søren Hammer
Denmark
Posts 953
Nicely done Wink
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Page 1 of 1 (7 items) | RSS
