Hello!
Tech specs says that there are 4 HDMI inputs available - with in-built BR-disc player one gets "lost"; now I've read that the DVB-T2/C/S2 tuner needs another one...
Please help me: how many HDMI inputs are left?
I'd like to plug in: Set-top box, Apple-TV and PS3
Best regards
Elmar
There is 2 available. But if you dont need the built in DVB tuner, then you can unplug this one, and you have 3 left. I did that when I used a separate setop box.
You could also consider a HDMI expander, to which you can connect 4 HDMI sources. I am still considering this.
beolion:There is 2 available. But if you dont need the built in DVB tuner, then you can unplug this one, and you have 3 left. I did that when I used a separate setop box. You could also consider a HDMI expander, to which you can connect 4 HDMI sources. I am still considering this.
