Beosound 8 left bass speaker buzzing at lower volumes
stevo1352
Posts 2
stevo1352 Posted: Thu, May 16 2013 1:07 AM
Hello,
Can anyone let me know if their beosound 8 makes a fuzzy noise if you are about a foot away when listening to certain tracks on just the LEFT bass speaker. It usually makes fuzzy noise when the speakers are not being pushed or making any movements. Furthermore, It sounds PERFECTLY  normal when you are at a normal distance away or if the volume is above 50 percent when the ipad is docked.  It is not happening out of the right bass speaker. I think mine is slightly defective and do not want to have to go through warranty work if I have to as I feel that the repair center will not find any "issue". Thanks for your help everyone!
plumber77
Posts 76
plumber77 replied on Fri, May 17 2013 7:45 PM
Had the same issue only did it on certain tracks with deep bass.
I resolved it. The fret covers fit both ways but when I removed them and flipped them 180 degrees and played the same tracks issue was resolved. Hope that helps.
Page 1 of 1 (2 items) | RSS
