Hello,
one of my LC2s just stopped responding to IR commands, it worked fine for a few days (recently bought it) but now it has stopped working. Touch is still working though so the whole unit is not broken.
I have tried moving it around in my apartment to see if this was caused by some interference (yes I have a plasma) but I cannot get it to work.
I have a couple of other LC2s which works fine in the same outlet and I have tried replacing the dome.
Does anyone know if this could be some programming issue - can one program a LC2 to stop responding to LIGHT + LIGHT on the Beo4? (I was trying to reset the light levels the other day but as I was reading instructions for a Beolink 1000 I might have messed something up)
Anyway, if noone has any quick idea, could you please tell me how I should go about to replace the IR receiver - I have one LC2 that I use for spares so I am hoping I could salvage parts from that one. Also could you please point out where the IR receiver is :)
Thanks!
Pictures are from my salvage LC2:
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
iR receiver assembly is a top small shielded plate. It soldered in to bottom plate with 3 pins (on first photo P1, near electrolytic capacitor on right).
For desolder it you need first desolder metal cover from it.
Best,
Aleksei
The diagram below may assist you:-
Regards Keith....
This morning it worked again, have not done anything with it compared to yesterday evening when it did not work...
Cannot think of anything except that it might be the sunlight or temperature (it's placed in a window). I'll leave it as it is for now and hope that it will stay this way...
This is really starting to bug me...
...and now it has stopped working again lol
I'm suffering exactly the symthoms you described. The LC2 responds to the remote from time to time.
Did you finally solve this issue?
Nope, never did...
I have a same problem. Do you have any solution on this LC2 "working-not working" problem? I get crazy on this...
Thanks, Korte
Bad IR receiver..
https://archivedforum2.beoworld.org/forums/p/11884/103685.aspx#103685
/Weebyx
