Hermann_5F00_:Is there a way to have a Screensaver at BV11 while I listen music or radio from BV11?
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
@Michael: But then i can't listen music from home media.
@DGRouge: With your tip I found also p.media. This is the solution, thanks a lot.
Hermann_: @DGRouge: With your tip I found also p.media. This is the solution, thanks a lot.
I also use P. MUTE but that is not a screen saver, but of course it does probably save the screen :)
