Dear All,
I would like to setup my beo5 to Control a Beomaster 3500 (i know, its old) .. Is this possible? And if yes, how? I already managed to setup an LG tv to Go with The beo5.
many thanks in advance!!
Onne
Yes, sure - it`s possible.
Just select an audio system in the config tool that matches the products you need - for example Ouverture
(RADIO - CD - A.TAPE).
If you have a Beogram add the N.RADIO button, because in today`s Beolanguage PHONO is N.RADIO...
Maybe you also need A.AUX. You can add these buttons to select a source with control functions in a submenu.
You won`t need the colour buttons, because "the old" BM 3500 doesn`t know these functions.
Stefan
