two Beomedia 1's in one ip network
This post has 2 Replies | 2 Followers
georgey007
Posts 74
georgey007 Posted: Tue, May 28 2013 4:04 PM
Hi
I do have 2 separate Masterlink Networks in each of them one Beomedia 1 for n.radio; the Beomedias connected to one ip network, and here is the problem both have the same network name (not ip) an either one is giving me an error (same name). I also can only connect via BeoConnect to only one I have to switch off one of them to connect.
Is there a way to change the computer name in the XP service menu ( I tried I couldn't do it)
pls help  regards
hfat
Vienna, Austria
Posts 663
hfat replied on Tue, May 28 2013 4:51 PM
Yes, you can change the network name:
You activate the service menu (0 0 ENTER)
and activate the "Show Service Menu" option in the system settings
Return to the main menu and select "SERVICE"
You get to the XP desktop
There you can access the workstation properties and modify the workstation name to eg: BEOMEDIA2
When finished you press the ESC key to return to BM main menu and reboot
hfat
georgey007
Posts 74
thanks works great now
Page 1 of 1 (3 items) | RSS
