Hi
I want to swap my avant and bv3 round so that bv3 is the master - however the BV3 doesn't have an RF Modulator, does anyone know if the one in the avant will fit the BV3 and work in the same way?, looking at it it is one board and I seem to recall that the parts are interchangable but wanted to check first before I do anything dumb. Also is it just the one board that has to be changed?
What size is your BeoVision3?
Although the 28" and 32" look the same they are different chassis internally. The 32" is the same as an Avant so I would guess that the RF modulator is interchangeable.
If your BveoVision3 is a 28" it may not be. Sorry to be vague, but more information may assist someone more technical to answer your question.
Opman
Hi, thanks for the quick reply - both of them are 32" and the Avant is a VCR RF
