greetings,
looking for a MMC 20CL cartridge in ex. working order - does not need to be new however well preserved
but please no silly $$$ offers
cheers, ALF
Since there is more than one country using $$$, it would help if you told us all where you are!!
You can enter this information in your profile and it will be displayed in the avatar area in all your posts.
How many $ do you expect to pay since I wouldn't want to make a silly $$$ and they are expensive to buy.
Regards Graham
hello graham,
price would depend on whether it is NOS or a good 2hd cartridge - it is for my 4002 table :-)
my initial price idea was around the $150, but as said: it depends !
it is all about being there at the right time if one is on offer and they are not always madly expensive :-)
cheers ALF
$150 seems low for a CL, US or AUS.
But I'm no expert.
I would suggest getting an old cartridge, a broken one will do, and having it retipped by Axel as a CL - I think he can do that.
Peter
