Digitise a few vinyls
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
joeyboygolf Posted: Sun, Jun 16 2013 5:44 PM
I decided to get a few of my albums which I only had on vinyl onto my computer. But how??
I purchased an American Audio, Audio Genie II for £24 on Amazon.co.uk. Ordered a 7 pin DIN socket to 2 Phono Plugs adapter from steve@soundsheavenly and downloaded the most recent edition of Audacity software.
I used a Beogram 6500/MMC2 combination as the front end and gave it a go.
The results are really quite astonishing for such a low cost A to D converter. The clean up routines in the software are extensive and easy to use.
I'm chuffed.Yes - thumbs up
Regards Graham
Ricardo
Moonbase 5
Posts 418
Ricardo replied on Sun, Jun 16 2013 5:52 PM
I like mine with the CD Spin doctor software, but I am always either too busy or too lazy to use it.
Søren Hammer
Denmark
Posts 953
I am using the tape output from the Beomaster, straight into my interface (Zoom R16 8 channel recorder) - recording in 24 bit, 44.1 kHz sampling rate. Some processing is done in Cubase 5 or Audacity, with the final result exported in 24 bit .flac or ogg vorbis Smile
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Page 1 of 1 (3 items) | RSS
