The battery in the BeoCom2 is about the only serviceable item. Its fiddly though. You need to remove the two torque screws form the base and then remove the battery pack. This is ideally done with a special tool.
The replacement battery is part number 8700055.
Regards
Opman
I'm sure they're still available but you might consider having them do it since it's not easy without the special tool.
