Søren Mexico: Here the lifter part Sorry wrong pic, here goes What did you do with yours, run it over with the SAAB or feed it to the dog, please hurry up with the address I´m leaving for El Salvador on Sunday
So, you didn´t get my mail?
Ok, here´s my address again:
D i c k Andersson
Lindrothsgatan 18
S-70367 Örebro
Sweden
Thank you in advance, Sören!
http://tinyurl.com/qj9cjsf
tamtapir:So, you didn´t get my mail?
Found your mail it came away in the crowd, you have a PM
I would like to know if you still have the arm of the RX. Specifically, I need the rubber tip at the rear of the arm that allows the counter weight to stay on the arm. I will gladly pay you for it.
Manny
big_daddio: Hi, I would like to know if you still have the arm of the RX. Specifically, I need the rubber tip at the rear of the arm that allows the counter weight to stay on the arm. I will gladly pay you for it. Manny
Sorry Manny, I shipped that together with the support parts to Tamtapir in Sweden, try him, he maybe can help
I am one of those stupid people who tried to take the tonearm off a 2542 model and accidentally pulled the wires out of the tube. Now, years later, I want the turntable to work again, so I need a replacement tonearm with the wires marked at the end so I can resolder them to the right place. Do you have anything like this or can you recommend a source? I tried K-Mart, they are out. : ) The reason for the attempted repair was that one of the rubber grommets on the shaft that holds the counterweight was chewed up and would not hold the counterweight on, but this shaft should be part of the tonearm complete assembly. I do not need the stylus, unless it is an MC5.
Thanks,
Lee ljwhisn@sbcglobal.net
Hi Lee, traveling at the moment, will check when I get back.
Welcome to the forum
