Beocenter 2300 - Red AND Green Light Lit on Standby..
This post has 6 Replies | 0 Followers
MediaBobNY
Greenwich Village, NYC
Posts 1,106
MediaBobNY Posted: Tue, Jul 16 2013 3:23 PM
I may purchase a BC 2300 for sale locally.  It seems to check out fine; however, upon standby both the red and green lights are lit.  When it's in use just the green light is lit.  Ordinarily, two lights on during standby would mean the timer function has been activated but there is no such feature on the 2300.  The set-up guide and user manual are of no assistance.  Alternatively, is there a way to do a factory reset, which might turn off the green light during standby?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Tue, Jul 16 2013 3:49 PM
As far as I know does that mean that the timer play function is active.
No faults.
MediaBobNY
Posts 1,106
As mentioned, no such thing on a BC 2300.
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Jul 16 2013 5:59 PM
I am pretty sure that if you press MUTE (on the system panel, NOT on the remote) when the system is in standby the extra 'timer' light goes out.
Although your system probably doesn't have the timer the light being on means it would be initiated by another part of the system if connected as a slave in a link room.
More info here: http://archivedarchivedforum2.beoworld.org/forums/p/19304/143602.aspx#143602
BO
Halmstad, Sweden
Posts 728
BO replied on Tue, Jul 16 2013 6:05 PM
Green light on = timer on. Described in the manual.
//Bo.
A long list...
AdiS
Posts 170
AdiS replied on Tue, Jul 16 2013 6:24 PM
it is an old BeoCenter 2300 perhabs? With the sensor on the left side on the black panel under the glas doors? If it is, it has 2 way communication and then you can use the timer function only by using Beolink 5000 or BeoLink 7000.
regards, Adrian
MediaBobNY
Posts 1,106
Guy:
Absolutely correct in everything he said.  Problem solved.  Thank you Guy!   Yes - thumbs up
Page 1 of 1 (7 items) | RSS
