Hello BeoWorlders,
I decided to post this information in the General Forum, as it might be interesting to users allready having a Beo5/6 and others probably thinking about getting a Beo6.
During the migration from version 4.11 to version 5.12 and modifying my setup (BV10 will be replaced by BV12 next week), I encountered some issues with the config tool. I took the opportunity to take a closer look at the tool. I compiled a guide that guide summarizes the experiences gathered during this process. I want to share this information with you and added a page to the Beo5/6 Wiki page, where you can download the guide.
hfat
Brilliant!!
Thanks for this useful work.
Kind regards,
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
hfat:During the migration from version 4.11 to version 5.12 and modifying my setup (BV10 will be replaced by BV12 next week), I encountered some issues with the config tool. I took the opportunity to take a closer look at the tool. I compiled a guide that guide summarizes the experiences gathered during this process. I want to share this information with you and added a page to the Beo5/6 Wiki page, where you can download the guide
Hfat,
I have to say that you have produced a truly excellent document which I hope will be very useful to Beoworld Members. I have studied it and it has clearly taken you a lot of work to put together. Well done and thank you..
Regards Keith....
Wonderful job.
While I was happy with my "blind" configuration, your guide has brought so much to light -that I have already started to rethink some of it, as I can now see where I can make some improvements.
Thanks so much for a finely produced guide and all of the effort that you put into it!
Thanks for the guide it is great and made me re-think about having another go at re-programing mine beo5
Thank you all for your feedback.
Some of you PMed me with additional feedback. So I took the opportunity just finalizing my new configuration (BV12 arrives on tuesday) to put together a second version. Some additional step-by-step instruction are added and some new features are introduced. I packed some sample files together with the guide into the zip-file. Unfortunately they use German as the remote's language. I hope you can manage.
You can download from: http://archivedforum2.beoworld.org/members/hfat/files/Guide-to-BEO6-Configuration-_2D00_-V2.zip.aspx
PS: I havn't yet figured out how to insert links correctly. Perhaps somone could explain. >>> I have added the link for you. To add the link just highlight the text you want as a link and press the "Chain" button located under the word "Paragraph" above when writing or editing a post and a window will open allowing you to enter the URL.. Keith
Also from here, many thanks for the dedication for such time consuming work!
A complete referencebook for the Beo5 user which wants/needs a (new) challenge.
Thank you !
Beobuddy.
