Hi
If a pair of bl3 (or any other activ speaker) is used with a master audio (for example bs5) and if this one is connected with masterlink to a beovision (7 40 for example):
will it be possible to use the bs5's bl3 as rear speakers for the bv 7 when I watch movies in 5.1 ?
The idea is to save some pwlink cable and some work (wall integration)
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
If it is worth it, I don't know....
....but it might be possible to use a Bosscom (or Lmando) PowerLink Switch, and - since you don't want to run cables - a Bosscom WirelessPowerLink2 from the BV7 to the rears.
Greetings MM
