Maurice posted on Mon, Aug 26 2013 6:59 PM Hi beo guys and gals I have recently been given a BC1 with the following problem. The set starts up with a beautiful sound & picture on either stb or the built in DVD, however on any picture input it has a pinching in of the picture at the top and bottom both sides eg slight horizontal symmetrical contraction and in the mid hight a pronounced inward curvature. The fault happens if I gently tap the contrast screen and if i even touch the gegauss cable. I have tried to induce the fault by gentle mechanical tapping on PCB4 to no avail Having researched this fault It appears to be a pincushion fault but the degauss cable defiantly reproduces the fault. with no schematic on this site avail I am stuck if anyone can it would be greatly appreciated. regards Maurice Quick Reply Filed under: Becenter [Edit Tags]
regards Maurice
