Beo6 stand alone with lg50pg6000 and Samsung 3126 settopboks
This post has 1 Reply | 0 Followers
peterrask
Posts 3
peterrask Posted: Wed, Aug 28 2013 8:19 AM
Is it possible to use the boe6 as a Remote for this setup. Have not Got any b&o products. But dó have the configuration tool
Rivenflush
Gothenburg
Posts 333
Absolutely as long as you can find / make an xml fil for it. Search the forum and you will probably find a LG TV file that works and possibly a Samsung as well (the models very rarely have unique IR codes).
If you do not find them you can try to make a file from Pronto codes using the software Keith has done (converting tool)
Br
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
Page 1 of 1 (2 items) | RSS
