I am trying to find the power output (in mW) and the impedance (in Ohms) of the headphone amp integrated in the three following vintage products: Beomaster 4500, Beomaster 7000 and Beocenter 9500.
Would anyone know? Many thanks in advance!
The quoted outputs are volts into certain impedances :
4500 - 15V into 220Ohm
I can find the 5000 which is 10V into 470Ohms
9500 - 8V into 220Ohms
The BM4400 is quoted as 17V into 200Ohm.
Peter
Thank you very much Peter.
Do you think these 3 audio masters have sufficient internal headphone amps, or would they benefit from the addition of an external headphone amp to drive somewhat inefficient headphones (or to drive a pair of H6, which tend to produce much better bass when amped)?
Many thanks again.
Sorry, double post
