Using Phono Input as extra Line-In
This post has 13 Replies | 0 Followers
Guy
Warwickshire
Posts 2,590
Guy Posted: Thu, Sep 5 2013 1:03 PM
Has anyone tried one of these?
http://www.ebay.co.uk/itm/Bang-Olufsen-DIN-Phono-input-adapter-Plug-your-CD-DVD-Tape-into-Phono-input-NEW-/161085665657?pt=US_Audio_Cables_Adapters&hash=item2581743179
I need an extra line-in on my BC9500 and wondered what the sound quality would be like with this?
Orava
Finland
Posts 991
Orava replied on Thu, Sep 5 2013 1:14 PM
Haven't try, but.... but... One could expect it to do something to sound as it needs to do "anti-riaa correction" and so... If this were my problem, I would bypass internal riaa amplifier.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Sep 6 2013 9:15 AM
Thanks - I thought about an internal by-pass but I don't really want to muck around inside my BC9500 - I like to keep it original!
Alternatively a manual 7-pin DIN switch box could help, but most of the input selectors that I have seen are 5 pin only, hence I wouldn't get the pin 6/7 data connections.
I might try the phono input adaptor and if the sound quality is poor I may have to build a switch box.
Orava
Finland
Posts 991
Orava replied on Fri, Sep 6 2013 10:27 AM
If you build yuorself switchbox, you can use 8-pin female din connetors. they have 7 round and one in the middle, comtabiabe with B&O 7-pin male connectors.
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Sep 6 2013 10:45 AM
Did you see this on www.ebay.co.uk?
Aux (Audio) Expander Control (For B&O Audio Systems)
Ralf
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Sep 6 2013 12:03 PM
Thanks Ralf but one of the two devices I'll be connecting needs the data connection also - hence the requirement for the 7 pin DIN inputs.
The AUX/TV is connected to my BV3, and the TAPE2 is connected to one of these:
which is a B&O compatible Internet Radio/DAB/Music player that uses the data connection.
the_o_master
Posts 856
You can try to find this switch:
Vintage Bang & Olufsen
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Sep 6 2013 12:16 PM
Looks perfect - I assume that the inputs are 7 pin DIN?
the_o_master
Posts 856
Guy:
Yes, they are...
I sold this piece few months ago Sad
They are fairly rare but one will occur on Ebay for sure...
Millemissen
Flensborg, Denmark
Posts 14,680
The pins are 7-pin!
It is made exactly for this/your purpose.
I have one - in use Stick out tongue  - everyone should have one Stick out tongueStick out tongue
BUT you must have good lucks to find one - unfortunately.
A modern version of this is this:
http://shop.oneremote.dk/catalog/product_info.php?cPath=5_6&products_id=3494&language=en
Greetings Millemissen
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Sep 6 2013 1:09 PM
Many thanks to you both - I will start looking!
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Sep 6 2013 2:01 PM
One more idea: STEVE
Aux Input "Y" Splitter/Doubler Adapter
Ralf
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Sep 6 2013 2:37 PM
Ralf,
Thanks, I might try that one. Of course I would then add the splitter to my AUX/TV input, which is currently connect to the ML Converter and BV3.
I then assume that simply pressing AUX on BC9500 (or A.AUX on Beo4) would give me the additional input. This would be my Playmaker in fixed volume mode.
I suppose that the BC9500 can then differentiate between the new input and a deliberate selection of the TV as an input - where AUX 1 = TV, AUX 3 = SAT, AUX 4 = DVD/V.AUX/V.MEM.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Guy:
Here's a completed auction for one.  I have one (not for sale).  Leslie probably has around five of them - you might want to contact him.
Page 1 of 1 (14 items) | RSS
