distortion on 180 Gram vinyls
This post has 9 Replies | 0 Followers
erandlux
Posts 116
erandlux Posted: Sun, Sep 8 2013 2:19 PM
Hello guys,
I have since a few month a beogram 7000 connected to my beomaster 5 via an USB converter.
It works damned good but I have a problem with 180 Gram Vinyls, just like if it was too heavy for the beogram.  Any ideas on what it could be ?
Regards
Eric
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
The Beogram probably needs a new drive belt.
Regards Graham
henrik
Sweden
Posts 458
henrik replied on Sun, Sep 8 2013 7:49 PM
What's the problem? Distorted sound, wow&flutter or something else?
I've had problems with distorded sound on quite a few 180g vinyls on my bg7000. The same records sound good on my Pro-Ject turntable (that I have hidden in a cupboard, haha), so the records are ok. It's just like the bg7000/mmc1 can't track these records correctly.
erandlux
Posts 116
The sound is too slow, with a wow effect, really strange sound. I have a new SMMC4 from soundsmith, and no problems with normal vinyl, event new ones. Just with 180 gram.
Maybee i have to buy a another non BO turntable ;-(
I will anyway try to,change the belt and see what happens.
henrik
Sweden
Posts 458
henrik replied on Sun, Sep 8 2013 9:25 PM
Ah ok, speed issues. Then follow Graham's advice. :)
joeyboygolf
Posts 4,188
These tangential turntables are 17+ years old and they ALL need at least a new drive belt and possibly a new servo belt.
It is by far the cheapest way of improving the sound quality of your turntable.
Every turntable I sell gets a new drive belt and then tested with a 180g vinyl copy of one of my test records.
They all sound fantastic.
Regards Graham
beowild
Posts 53
beowild replied on Mon, Sep 9 2013 10:14 AM
Hi
I have a BG3500 and never had problems listening to 180g vinyl records. Also my former turntables (BG3000 and BG6500) which have almost the same mechanics never had problems with 180g vinyl.
They really sound fantastic, so it is worth the work or money to repair.
David
erandlux
Posts 116
erandlux replied on Tue, Sep 10 2013 3:57 PM
Thanks for all your advices, I have ordered a new drive belt from my dealer.
Just need to know what is the servo belt... And if it needs a new one.
joeyboygolf
Posts 4,188
erandlux:
As far as I am aware the belts are no longer available from B&O. You would be better of ordering from Beoworld member Dillen .
The servo belt drives the gears that make the arm move across the record. They need replacing less often than the platter drive belt, in my experience.
Regards Graham
Redline7700
Posts 31
Raise the weight ever so slightly. 180gm vinyl was very rare when these decks were new.
Page 1 of 1 (10 items) | RSS
