Is this an easy fix my friend has just brought a beocenter 9500 radio works fine ,gets sound through the radio. However the CD player just spins the disc with no sound. Also the panel refuses to open on the tape deck .this was a cheap purchase and he was wondering if it is worth saving.
Absolute worth saving. The cd player probably need some new caps and the tape deck panel needs a new belt.
Easy fixes.
//Bo.A long list...
Thanks, I passed it on but he said he didn't want it so I am now it's owner. I have a beomaster 5000 amp with RL 60.2s I wanted to complete the system with turntable and CD player. But I think I might get the 9500 fixed up and use my beogram 1600 with a mmc20 en. Do you think this we be just as good as the beomaster 5000 set up. I love the look of the 9500 does it have as much power as the 5000? Thanks.
