Beomaster 1900-2 switch-on noise
This post has 3 Replies | 2 Followers
filbip
Posts 3
filbip Posted: Mon, Sep 16 2013 3:25 PM
Bonjour (from France),
I've fixed some problems on my BM 1900-2 (hum/C66, bulbs, ...)
But a small problem persists.
When I switch it on, choosing a source from standby, I hear "pop" in the speakers.
The muting circuit seems to be OK. When I increase the value of the C98, the sound rises gradually after the "pop" noise. I changed the electrolytics near the TR207/307 with no results.
The muting is OK when switching fron one source to another.
Any suggestion would be welcome.
Thanks for reading
Philippe
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Sep 16 2013 5:11 PM
Mmm... The usual suspects here are input capacitors. No such pops on my 1900-2 though. That said a thump at startup is quite normal with many amps that do not have a delay relay.
Do you get the pop at  tape-out? Is it very loud?
Jacques
filbip
Posts 3
filbip replied on Mon, Sep 16 2013 10:48 PM
same problem without any input (P2 disconnected from preamp board 4).
I don't have an osciloscope but my multimeter shows a temporary offset of  0.3/0.5V. It decreases immediately to 30/40mV.
The 31V and other voltages in amp section seem all OK.
The pop is not very loud but unusual.
I didn't test tapeout...
Philippe
filbip
Posts 3
filbip replied on Tue, Sep 17 2013 7:25 AM
I did the test with tape output. It is perfectly silent when switching on.
The problem is clearly a poor stabilization on the zero Volt output (speakers) when 31V is comming on). I didn't find the culprits...
Philippe
Page 1 of 1 (4 items) | RSS
