Something is wrong with this 4500 glasspanel
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie Posted: Wed, Oct 2 2013 9:37 PM
Saw this on Ebay, looks I have some competition but somehow there's a design fault with this glasspanel
Brengen & Ophalen
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan replied on Thu, Oct 3 2013 12:48 AM
Well, for a start I would never buy from this seller again!
Nobody likes getting ripped off Super Angry
x:________________________
Orava
Finland
Posts 991
Orava replied on Thu, Oct 3 2013 6:43 AM
Leslie:
It has echo Surprise
Leslie
Posts 5,423
Silver Member
Leslie replied on Thu, Oct 3 2013 7:46 AM
It has a redundant touch feature, in case the lower doesn't work you may try the upper...
Brengen & Ophalen
raybody
Posts 16
raybody replied on Thu, Oct 3 2013 8:24 AM
the upper section is where the display lights shine through,
during the manufacturing process of removing the black coating its impossible to remove with a cnc laser machine just the coating without having an effect on the glass, leaving it with a mild etching to the glass.
B&O must have had the coating applied to just the areas needed excluding the "shine through" sections for the display to show but thats almost impossible to do on a small scale.
All the functions work as they should it just looks a little different.
i am sure you must all agree its better than a system without any glass panel and if it doesn't match the rest of your system then just replace all panels so they match!
all 3 available below
http://www.quality-dream-audio.co.uk/replacment-glass-panels/PANELS.html
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
raybody:
I thought you did a better job, Leslie!
Regards Graham
Leslie
Posts 5,423
Silver Member
Leslie replied on Thu, Oct 3 2013 1:59 PM
raybody:
To be honest now you mentioned that, I have the same issue with my 4500 glass panels that I've made a while ago, so same thing for my glass panels Embarrassed
Something to think about for my future panels (incl. CD4500).
For the one who's interested, this is where I laser "engraved" my glasspanels...
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Thu, Oct 3 2013 2:00 PM
joeyboygolf:
raybody:
Not really Graham!Ick!
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Thu, Oct 3 2013 2:04 PM
raybody:
At least much and much better then the black panels someone sold or still sells on Ebay UK
I had a customer at my home buying one of my panels and he showed me the black one he bought on Ebay. Its was black glass with aluminium foil on the back side
Brengen & Ophalen
Page 1 of 1 (9 items) | RSS
