IR Eye
This post has 4 Replies | 2 Followers
beoaus
Posts 177
beoaus Posted: Mon, Apr 9 2012 8:36 AM
Hi, its been a while.
Like the new forum and thanks to all for the effort involved.
My IR Eye on a on a beo link active kit no longer responds. It flashes a light when a button on the remote is pressed though it no longer activates? Any ideas?
cheers and thanks, beoaus
carrera356
Posts 2
Hello beoaus
Have you solved the problem as I have the same issue and am looking for a solution.
Millemissen
Flensborg, Denmark
Posts 14,680
Must not be the ir-eye - please check your MasterLink connection(s) as well.
beoaus
Posts 177
beoaus replied on Tue, Feb 25 2014 9:48 PM
The Beolink Active is wired into the wall. I turned off the circuit breaker to reset it.
Thanks.
Millemissen
Flensborg, Denmark
Posts 14,680
All the same, there probably is a ML-junctionbox somewhere.
I am not saying that it is faulty, but it is worth checking it.
How many other ML-components do you have in the setup?
Page 1 of 1 (5 items) | RSS
