OneRemote HDMI switch for BeoVisions
This post has 8 Replies | 0 Followers
ClausMikkelsen
Posts 26
ClausMikkelsen Posted: Sun, Oct 20 2013 7:35 AM
Hi all,
Do any of you have any experience with OneRemote HDMI switch for B&O tv?
I would love some more HDMI inputs for my BeoVision 8-40 and came across this solution from OneRemote. Both the Gefen and Atlona options are way to expensive to me for a few more HDMI's. This one is way cheaper, but does it work?
http://shop.oneremote.dk/catalog/product_info.php?cPath=31_33&products_id=3299&language=en&osCsid=bc7q2q75vela10j9o7gg3q2vb4
karlquist
Posts 44
karlquist replied on Sun, Oct 20 2013 7:46 AM
hi ,i use the marmitek hdmi switch  costs 35 euro,s and works perfect
grt cvb
ClausMikkelsen
Posts 26
Hi karlquist and thank you for your answer.
Which PUC is used to control the switch? :-)
elephant
AU
Posts 8,219
elephant replied on Sun, Oct 20 2013 8:33 AM
ClausMikkelsen:
My question too :)
Their website says "Operate your connected A/V equipment remotely via the infrared return signal" - I hope this means remote Beo 4 controls ?
BeoNut since '75
ClausMikkelsen
Posts 26
I'm googling like crazy for different solutions... and though it is more expensive than OneRemote, Marmitek and a ton of other brands, then I'm enchanted by the Atlona AT-HD4-V42... Would be great with two outputs - maybe I should add a projector? ;-)
But if I add a switch with PUC control, I will be loosing an IR input on the television and only have 3 left for my 4 HDMI inputs? Correct?
Millemissen
Flensborg, Denmark
Posts 14,680
The problem in general about adding HDMI-inputs is that you soon run out of PUC's - and there is no PUC-extender!
StUrrock
Posts 995
StUrrock replied on Sun, Oct 20 2013 6:07 PM
Millemissen:
Yes there is a way to extend PUC control :)
http://www.bang-olufsen.com/en/picture/beo6?gclid=CIHy9vDypboCFSXItAodQRkAIw
Millemissen
Flensborg, Denmark
Posts 14,680
......a pretty expensive one 💰
ClausMikkelsen
Posts 26
I'm so glad for your responses.
f I add the Atlona switch with 4 inputs and 2 outputs, will I then have 4 or 5 HDMI's available on my TV?
The switch will be added to HDMI B, which gives the inputs B1, B2, B3 and B4. But is HDMI A still in action or will it be unavailable, when I add the switch?
Page 1 of 1 (9 items) | RSS
