which 24 bits FLac are read on a bm5
olvisab
Posts 1,391
olvisab Posted: Fri, Oct 25 2013 10:18 AM
Hello,
I have tried several Flac 24 bits hd test files from the LINN website and the only one that can be read by my BM5 is the 24bit 88.2kHz 5.1 Surround FLAC test file.I have absolutely no sound for the 24 /96 and 24/192 files.
Please, let me know what's working for you.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
VANTAGE
Posts 88
VANTAGE replied on Fri, Oct 25 2013 11:14 AM
96 KHz/24 bit FLAC-files bought from hdtracks.com (or similar sites, eg. qobuz.com) work perfectly on my BS5/BM5 - but they are not in 5.1 though. I do know they are in 96 KHz/24 bit, as I have analyzed them with the appropriate software.
I get no sound indeed if I use 192 KHz/24 bit files. Maybe the fact that your 96/24 test files do not work is due to the fact that they are in 5.1?
Hope this helps.
VANTAGE
Current: Beovision Eclipse 65" v1 - Beolab 50 - Beolab 28 - 2 x BS2 (GVA) - 1 x BS1 (GVA) - Beoremote Halo - H9i
Past:
Beovision MX4000 - Beovision 3-32 - Beovision 7-55
Beosound 9000 - Beosound 5 / Beomaster 5
Beolab 6000 - Beolab 8000 - Beolab 5 - Beolab 3 - Beolab 17
olvisab
Posts 1,391
olvisab replied on Fri, Oct 25 2013 12:21 PM
Hi vantage,
thanks for your answer.
It is not really a 5.1 file, and this one is the only one who works. Nothing in 96 works.Neither in 192.
Maybe with the arrival of the wisa speakers (192,320 capabilities), there will be an update of the bm5 in order to be able to read these hd files.
Best regards
Olivier
VANTAGE
Posts 88
VANTAGE replied on Fri, Oct 25 2013 12:48 PM
Hi Olivier,
Weird - I heard that the new B&O WISA speakers would support files of up to 24-bit/48 KHz (ie. not 88, 96, 176 or 192 KHz), but maybe I got it wrong?
Klaus
Past:
olvisab
Posts 1,391
olvisab replied on Fri, Oct 25 2013 12:55 PM
My source of information is not the more trustable.
So maybe it will stay like this.
Wait and see Klaus
This doesn't explain why I can not read 24/96 files whereas you do.
Puncher
Durham
Posts 11,729
Puncher replied on Fri, Oct 25 2013 1:05 PM
VANTAGE:
Hi Olivier,
Klaus
I believe you are correct, I think Olivier may be getting mixed up with bit rates for lossy files, i.s. 192kbps, or 320kbps.
Ban boring signatures!
olvisab
Posts 1,391
olvisab replied on Fri, Oct 25 2013 5:36 PM
Puncher:
You're probably right Whistle
For the 24/96 I confirm that it works perfectly.
Page 1 of 1 (7 items) | RSS
