I recently bought a mk2 Beovision 6-26 with the DVB-T module fitted which works through the SAT button on the remote. The tv has a DVI socket and component input. I have been able to get a picture using PC mode on the remote through the DVI socket but the component video connection does not seem to work when i tried with a DVD player (or at least i wasn't sure which button on the remote turns it on).
I would eventually like to be able to use an apple TV3 with the tv but wondered if anyone has had success with this as there is not HDMI input.
I noticed on amazon there is a device which connects the ATV to a VGA/3.5mm audio output which i believe i could connect to the tv - has anyone tried this or similar? There are other cheaper devices on ebay which seem to do the job but this looks like a neater solution and does not require an additional power supply.
http://www.amazon.co.uk/Kanex-AirPlay-Mirroring-Projector-Apple/dp/B0082AFROO/ref=sr_1_sc_1?ie=UTF8&qid=1385728481&sr=8-1-spell&keywords=kamex+apple+tv
Scott.
Beocenter 8500 / Beolab 4000 / Beosystem 5500 / Beolab 8000 / Beogram 2000 / Beosound 8 / Beovision 6-26 / Beovision MX4000 / Beomaster 1900-1 / Beovox CX50 / Beoplay H4 / Beoplay A1 / Beocom 1401 x2
see this thread http://archivedforum2.beoworld.org/forums/p/6869/62166.aspx#62166.
This is how I set up my 7 and I'm really happy with the results, to access DVD on the BEO4 I just press DVD and then "GO".
Let me know if you go with the Kanex how it operates.
