Equivilant transitor search
This post has 13 Replies | 0 Followers
Christian Christensen
Stockholm
Posts 512
Christian Christensen Posted: Sun, Dec 8 2013 3:00 PM
The result of searching on alltransistor.com is a bit confusing for me.
While searching for AC126 as an example, the text result is
"See also transistor tor datasheet" followed by a list of transitors , is this to e interpreted as quivilant transistors?
Or does anyone know of a better seach enigine on the webb ?
/Christian
My re-capped M75 are my precious diamonds.
Orava
Finland
Posts 991
Orava replied on Sun, Dec 8 2013 3:21 PM
IF I do search AC126, it gives me " AC126 Transistor Datasheet. Parameters and Characteristics." page, and on it is, " AC126 Equivalent Transistors " link, leading to page where can search equalent by parameters... Did not find any with presets from AC126 datasheet. But now you can drop minor parameters away and try again...
tournedos
Finland
Posts 7,357
Orava:
Just omitting the last parameter (case = TO1) gives a number of results, but as this basically is an obsolete germanium transistor, many of them may be equally hard to find.
I can check the good ol' cross reference book (the one with physical paper pages...) tomorrow at work in case there's something useful in there.
--mika
Stockholm
Posts 512
Thanks Mika that would be lovevly Smile
my need at the moment is AC126 which sitt as main amplifier in the BM900 preamp, and the AC158, or AC128 a small effekt transitor which servs as feeder to the stereo indicator lamp from the stereo decoder.
I guess that the  feeder to the stereo indicatior feeder transitor parameters isnt so crucial
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Dec 9 2013 12:21 PM
The yellow ECA book gives the following equivalencies:
  • AC126 = AC 151, ACY 24, ASY 48 (only the first one might actually be helpful...)
  • AC158 = not listed?
  • AC128 = AC 153, AC 188
Dillen might know which current replacements actually work in these particular applications. I agree the stereo lamp driver shouldn't be too critical.
--mika
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Dec 9 2013 12:29 PM
I use AC151.
It's an excellent transistor, still available (I've bought on Ebay) and not too costly.
BO
Halmstad, Sweden
Posts 728
BO replied on Mon, Dec 9 2013 12:30 PM
I have AC 151 & 153 if wanted.
//Bo.
A long list...
Stockholm
Posts 512
Oh, many wonderful answers, thanks
I need 8 AC151. to begin with.
www.elfa.se in Sweden do have 151, they cost about 3 euros a piece including VAT
Elfa is has always had a reputation of good storage but with high prices
Anyone with other good links of component stores .
Bo, thanks so much for the offer. I could buy from you Smile , but I would rather save your private offered help when I am in  more tricky desperate situation Smile
RaMaBo
near Munich
Posts 626
RaMaBo replied on Tue, Dec 10 2013 8:10 AM
Christian Christensen:
Hi Christian,
you can try pollin.de as mentioned in the 300 Ohm antenna plug thread or  you can try  www.reichelt.de They send to foreign countries with a minimum order sum of 10,00 € and are very reliable. They exist since decades and now belong to farnell.
Ralph-Marcus
BO
Halmstad, Sweden
Posts 728
BO replied on Tue, Dec 10 2013 11:07 AM
Well I only have a couple of them so if you can source from elsewhere it's fine.
//Bo.
A long list...
Stockholm
Posts 512
actually going to to try out cheaper transitors, that are made in bigger bulks.
Will give you feedback
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Dec 13 2013 9:35 AM
try the following link in eBay. The seller is not me or any relative. You can also try to look for 'Germanium Transistor' in eBay you will find lots of them.
Ralph-Marcus
Menahem Yachad
Jerusalem, Israel
Posts 1,249
For the AC128, I used NTE158.
Menahem
Stockholm
Posts 512
Yes NTE 158 works, have used this on a couple of places.
It takes quite a bit current as pros, , but is very expensive.
Will soons try cheaper transistors on low.effect places, its on the list, and I will give you feedback as promised
Page 1 of 1 (14 items) | RSS
