Hi All
I have just received my NOW TV box and connected via HDMI to my BeoVision 7 32".
Set up was easily achieved and connected to my Wi-Fi network straight away. I checked the display settings on the NOW TV box and set it to 720P.
I can navigate to all menus and scroll through contents page with perfect picture.
HOWEVER, as soon as I try and watch a programme the screen flashes purple every other second. The menu and on screen graphics are unaffected. It is only the programme content that suffers. I have tried most channels including BBC News, Sky News, BBC iPlayer, 4oD Five on demand and Movies.
I have tried another HDMI cable and tried both of the two HDMI inputs on the TV to no avail.
I am stumped. Any suggestions?
Opman
Have you updated the NOW box firmware - apparently there was an issue where the moving picture would disappear, not the same I know but you should be working with the lastest firmware before chasing issues.
get the update by going to Settings > Software Update > Check Now.
Ban boring signatures!
Hi Puncher, Yes I have checked the settings of the NOW TV box and it confirms that I have the current software.
Hi Martin
The NOW TV box is connected via HDMI cable straight to the BeoVision7 32. I have two HDMI sockets and get the same result through both.
I have also tried changing the video display properties of the NOW TV box from 720P, 16:9 & 4:3. I still get the same fault on all settings.
Do you have another TV to check if the NOW TV box is ok?
Ralf
I tried it on my daughters LCD which also has two HDMI sockets but the box doesn't work at all on that. We just get a message saying video input not supported.
At least I get the menu and navigation when I connect to my BeoVision 7.
I spoke to a B&O service engineer who said that it sounded like a problem with the HDCP. He suggested that I go into the customer service menu and switch off the HDCP.
I did this but now instead of getting the flashing purple screen every other second, I just get a solid purple screen and no picture whatsoever.
I can't believe a box that costs just £9.99 can cause so much hassle. I am close to giving up and sending it back for a refund. Shame as the operation and menu navigation is so easy. Just can't watch any programmes :-(
The issue was resolved by updating the M2 & H8 software in the BeoVision7.Apparently there have been some updates to the HDCP.
NOW TV box works perfectly :-)
can I ask how much they charged to update the firmware on your BV7 and could you tell me the firmware edition number etc
many thanks Opman
Hi Mark
I work at the Bang & Olufsen store in Liverpool. I am not an engineer but have enough experience to use the service tool. I did it myself so no cost incurred.
Are you asking about the software because you have a BeoVision7 yourself? If you let me know the Type number I am happy to check the latest software values for your set.
Regards
Your type number 9334 is a mark3 BeoVision7 32.
Latest software for this version is:
AP sw 30.08 (Part number 8344946)
M2 sw 30.08 (flash)
DVD fep 1.1 (flash)
DSM sw 3.01a (part number 8344439)
Depending on which Freeview tuner you have:
DVB t 0.2.1.9 (flashed - no longer supported)
DVB HD 0.1.9.9.0 (flashed or via USB dongle)
I hope this is useful for you.
Opman: Hi Mark Your type number 9334 is a mark3 BeoVision7 32. Latest software for this version is: AP sw 30.08 (Part number 8344946) M2 sw 30.08 (flash) DVD fep 1.1 (flash) DSM sw 3.01a (part number 8344439) Depending on which Freeview tuner you have: DVB t 0.2.1.9 (flashed - no longer supported) DVB HD 0.1.9.9.0 (flashed or via USB dongle) I hope this is useful for you. Regards Opman
many many thanks Opman
Hi I am just about to get now tv box and looking to connect via small jack to rca and connect to my beovision 6 22 will this be a problem ??
