Beolit 600 (70's) FM problem
This post has 5 Replies | 0 Followers
Stonk
Marlow, Bucks, UK
Posts 2,070
Stonk Posted: Wed, Dec 18 2013 8:18 PM
Help! I sold my 600 via eBay and the buyer is complaining that it doesn't get to the lower range in the FM scale. I wasn't aware as I only used it in the mid section.
He has said:
'VHF/FM works, but something is wrong with the r.f. alignment because it doesn't tune lower than 89MHz which means it can't receive Radio 2 at all.
This is not caused by slippage in the drive cord, but something is off setting in the vhf alignment. Other than that VHF is ok.
Also the lower part of the AM ranges is not working quite right, which is probably the same misalignment.'
and
'I am technical, but not familiar with vhf radio alignment. I do have a suitable sig. gen. and am willing to have a go. The radio is tuning fairly accurately at the upper end of the vhf band, but is out at the bottom (87.5 MHz) end. With the dial set at 88 MHz it tunes about 90.5 MHz. So it is the spread that is out, and it just can't manage to reach Radio 2.'
Can anyone offer any advice? He has a copy of the service manual.
Many thanks.
If you think nobody cares, try missing a couple of payments.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Dec 18 2013 8:59 PM
Before aligning anything check the dial cord.
Maybe something in the cords travel (dial pointer?) or the way the cord has been fitted (or re-fitted if
previously serviced) blocks the travel before the tuning capacitor reaches its max rotational position.
Tune as low as it will go and check if the tuning capacitor can go any further if rotated by hand directly at the
pulley (carefully of course, not to snap the cord).
(Lowest tuned frequency = max capacitance = closed capacitor vanes).
Stonk
Marlow, Bucks, UK
Posts 2,070
Stonk replied on Wed, Dec 18 2013 9:15 PM
Many thanks Martin, I'll pass that on. I was hoping you'd respondWink
Christian Christensen
Stockholm
Posts 512
Excellent answer and explained by Dillen, had similar problem with a BM900 and BM 1200 just recently. ended up with just same mechanicly problem, even if solved a bit different in the two cases, but it was solvable.
My re-capped M75 are my precious diamonds.
Stonk
Marlow, Bucks, UK
Posts 2,070
Stonk replied on Thu, Dec 19 2013 7:25 PM
I've had a response....
"As far as I can tell, the dial cord is original and works ok over the whole length of the dial. The travel is not blocked at all, and the tuning capacitor goes smoothly goes from fully closed at the lowest freq to fully open at the highest. It's not possible to make it go down any further. I feel sure the problem is alignment drift, or perhaps something has aged out of spec in the rf section?
I checked the dial setting against the actual VHF frequency:
Dial set _ Actual Freq_Error %
104 104.1 0
101 101.3 +0.3
99 99.5 +0.5
96 96.8 +0.8
94 94.9 +1.0
92 93.3 +1.4
90 91.8 +2.0
89 91.0 +2.2
88 89.2 +2.6
Minimum tunable freq is 89.2MHz, too high to get Radio 2.
So the frequency alignment is OK at the top end, but the error increases as you go down in frequency. I need to adjust something that will reduce the tuning frequency only at the bottom end, but NOT at the top end…. i.e. the spread."
He clearly knows his stuff. Can anyone advise on the next step?
Steve
Dillen
Posts 13,191
Dillen replied on Thu, Dec 19 2013 8:58 PM
PM to you.
Page 1 of 1 (6 items) | RSS
