Beogram 1100 - won't play 45s
This post has 6 Replies | 0 Followers
McDonnet
Posts 8
McDonnet Posted: Mon, Dec 23 2013 1:30 PM
I believe the problem is the switch from 33 to 45 is not being made - any help on how to resolve most gratefully recieved
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Dec 23 2013 2:07 PM
I don't know the BG1100 but if it has the automatic record detect system (which I believe it does), if you put a 33rpm record on the platter, the blazck centre spindle is depressed and the correct speed will be played.  To play a 45rpm single for example, the middle of the record needs to be removed so that the centre spindle on the BG is not depressed.  That should then play at 45rpm.
Dave.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Dec 23 2013 2:13 PM
You will have to start playing by pressing the "45" corner of the square plate rather than the "33".
A bit confusing, really, since the 33 corner also bears the "Start" (or "Play") lettering.
McDonnet
Posts 8
McDonnet replied on Mon, Dec 23 2013 2:28 PM
I've been using the 45 corner but the speed wont change!
Dillen
Posts 13,191
Dillen replied on Mon, Dec 23 2013 6:50 PM
You will then have to inspect the mech. closer.
Something will have seized in dry lubricants and/or come lose.
McDonnet
Posts 8
McDonnet replied on Tue, Dec 24 2013 12:19 PM
Thanks - looks fine and arm moved to play 45s but speed is too slow. Very novice and not keen to play around as newbie!
Dillen
Posts 13,191
Dillen replied on Wed, Dec 25 2013 8:46 AM
Can you tell if the rubber idler wheel jumps from one section of the brass motor pulley to
the other when changing speed ?
Page 1 of 1 (7 items) | RSS
